Wanted : Microsoft Xbox advanced RGB scartlead or better
Discussion in 'Xbox Forums' started by neverenoughtoys, Apr 30, 2005.
  1. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    Wanted : Microsoft Xbox advanced RGB scartlead or better , have heard the microsoft one is the best , I also like the look of the ixos one , and heard the monster cable one is over rated.
    Ive got a third party switching box which does svideo , composite , and component and does coaxial and optical out for dolby digital , but the composite and svideo dont look very nice on my philips tv.
    So let me know what you have got , or what you think looks best , needs to be RGB and have either coaxial and optical out as well. All advice gladly received
    arjo
    I have read and agreed to abide by the AV Forums trading rules : Confirmed.
  2. Dr.Roboto
    Dr.Roboto
    i've got one spare, dedicated RGB gold plated scartlead with optical out, can't remember what make it is but it works fine on my tv
  3. justin@hc&b
    justin@hc&b
    Sep 6, 2003
    410
    Birmingham
    +12
    hi arjo mate
    i dont think you have noticed the little panel on the side of the switching box have you ??? take the flap off and there is a scart socket on there :D
    the switching box which does svideo , composite , and component and does coaxial and optical out for dolby digital its also got a SCART SOCKET ON IT ;)
    justin
  4. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    If its the genuine microsoft one I would be interested , could you find out
    thanks
    arjo
  5. Dr.Roboto
    Dr.Roboto
    its not, but my housemate has an official one and the picture quality is exactly the same (i tested them :))
  6. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    Doh , how much of a plank do I feel now :clap:
    when I read your post I ran to the front room and pulled of the flap and plugged in my qued scart lead and its like night and day difference . Its lot easier on the eye now , and a nice picture to look at . I can see a few diagonal scan lines very close up like someone said they could see with their mad catz leads. So I might still be on the look out for a microsoft official lead or better but not so desperate now.
    thanks for your help justin
    arjo
  7. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    Thanks for checking matey but no offence meant , but I cant take the risk buying a lead that is not any better then I got now , I think shipping is going to be the killer here , the shop just up the road from me sells full rgb leads for £4.99 and £9.99 just not the microsoft advanced ones.
    thanks for offering anyways
    arjo
  8. Family Guy
    Family Guy
    The XBox in RGB is not that great anyway...miles behind the PS2 and GC. If you carry out a search, there's plenty about it on these forums.
    I use an svideo connection...
  9. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
    That is strange that you say that familyguy as the box I got it with it does svideo, composite ,component and what I didnt know till last night and was told by justin , who I bought it off , :oops: rgb through scart.Now for some reason my philips tv really doesnt like the composite or svideo signals to it as ive tried and made sure it was selected to the right input in the tv . Now ive switched to rgbscart last night its giving a pretty good picture and was just wondering if the microsoft lead could improve on that .
    thanks arjo
  10. neverenoughtoys
    neverenoughtoys
    Mar 2, 2003
    451
    poole
    +10
