Can anyone recommend a retailer who will be able to supply a good quality 5 metre DVI lead for my A11 to Z2? My local supplier in Birmingham is having difficulty in sourcing one. Thanks.
Thanks, I gave them a look. The Lindy cable seems criminally cheap. Are they any good ar just tat? The DisplayMagic ables are more in the price range I expected.
The Lindy ones are just fine. Screw connectors are a bit weak but otherwise just fine. My 10m one works perfectly with the HTPC but my Yamakawa DVI player will not sync via it. However, a 9m Bettercables one (6 times the price) did not work either. I would suggest going no longer than 7.5m with the Lindy ones. Shorter than that will be just fine.
