Want to upgrade my viewsonic vmp 74
Bigeeeuk
My first post so take it easy. I want to upgrade my viewsonic vmp 74 player and was thinking on getting the Ac Ryan playon mini mk 2. Is this good player or is there better do not need an enclosure .
graham.myers
yep its OK. Its not got the best interface but the ones that are better are circa £200. Additionally if you dont like the interface you can replace it with the media8er one as they are the same chipset.
Podcast: Best Hi-Fi products of 2020, Plus Best of the Month for TV Shows & Movies
