Want to make ....
N
nealgs
Custom SCART -> SCART cable that is shorter than the usual .75m and 1m ones you can get. Also need to have straight entry/exit SCART connector rather than the 90degree ones you mostly can get.
any ideas on connectors/cabling - only really need to pass video they will be used as DVD->SKY->JSTechRGB2YUV so need to make 2 with RGB wiring (wiring diagram usefull to :) )
cheers
Gary
Podcast: Anthem AVM 70 Review, EQing Your Home Cinema Sound System and More...
