want to buy 5.1 system for ps3
Discussion in 'Home Cinema Speakers' started by shampali, Jan 20, 2008.
  1. shampali
    shampali
    Dec 25, 2007
    26
    hi guys I am looking to buy decent but really cheap 5.1 surround system for my ps3, I got my eyes on these http://www.amazon.co.uk/XPS-5-1-Speaker-System-Xbox/dp/B000V9GSE2,
    just want to know are they any good or are there any better speakers for maybe £20-30 extra! also what cable do I have to buy to connect it with the ps3
    any reply and help is appreciated :)
  2. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    To be honest mate you aren't gonna get a decent systemn thats really cheap. looking at that one it only has an output of 44 watts (I could produce more than that with my arse) How far will your budget stretch as it is really worth investing in something better. :thumbsup:
  3. shampali
    shampali
    Dec 25, 2007
    26
    thanks for the reply monkey :) the maximum I can spread to is maybe £70-80, and the reason for that is just recently bought Sony KDLw2000 so I am very short on cash for a very long time, but I am impatient as well so cant wait on saving up £200+ to buy a VERY good 5.1
    I can settle for a decent 1 for the price range I mentioned above but the problem is you cant find 1 which is compatible with ps3, they are all for PCs.........
  4. shampali
    shampali
    Dec 25, 2007
    26
  5. lfcmonkey
    lfcmonkey
    Mar 26, 2007
    1,219
    Doncaster
    +105
    Save save save it won't take that long and you can get the Sony HT-SS1100 for £200. Beg steal or borrow do whatever it takes but don't go wasting 80 quid on crap. :D
  6. shampali
    shampali
    Dec 25, 2007
    26
    just joking my friend :) as I said before it will take me a very long time to save that much and I really want the speakers as soon as possible, so please help on regards to that :thumbsup:
  7. zombie_donkey
    zombie_donkey
    May 4, 2003
    699
    +21
    Or buy second hand.
    You have to watch out for crooks and wrong uns, but there is a ton of AV equipment on E-bay.
  8. shampali
    shampali
    Dec 25, 2007
    26
    but how would you tell if they will be compatible with ps3? I know I am a n00b when it comes to speakers :(
  9. zombie_donkey
    zombie_donkey
    May 4, 2003
    699
    +21
    If you were to get a proper AV amp it will be able to hook up to a PS3.
    Just go on E-bay and do a search for 'home cinema amp'
  10. shampali
    shampali
    Dec 25, 2007
    26
  11. zombie_donkey
    zombie_donkey
    May 4, 2003
    699
    +21
    Probably just an optical digital cable.
    Get the cheapest you can find. No need to spend silly money on one.
  12. shampali
    shampali
    Dec 25, 2007
    26
  13. zombie_donkey
    zombie_donkey
    May 4, 2003
    699
    +21
  14. KHA2005
    KHA2005
    May 23, 2006
    30
    +3
    These speaker systems you've been suggesting are meant for PC use, and this meant I doubt (correct me if I'm wrong) they'll have an optical input. More likely they'll have 3 stereo type jacks used for PC and MP3 outputs, or phono inputs which the PS3 can't do. :eek:
    Tbh, with systems that price, I doubt they can improve that much on your TV's integrated sound, which is probably pretty good as far as they go. What I'm trying to say is that you have a superb TV costing at least £1000+, and I think a system like that would seriously let the system down.
    I personally would take lfcmonkey's advice and wait until you can afford a proper home cinema in a box system which is meant to feed quality sound to a large room, rather than 1 person at a desk.
    Good luck! :thumbsup:
    EDIT: This set for instance: http://www.amazon.co.uk/Logitech-Digital-Multimedia-Theatre-Speaker/dp/B0006HBCL8
    (although expensive) has an optical and coaxial input AND has Dolby Decoding which means it can take a signal from your PS3. I have heard these speakers, they are amazing! Believe me, its worth the wait for better stuff! Btw decent and really cheap very rarely go together :D
  15. shampali
    shampali
    Dec 25, 2007
    26
  16. gerbilly
    gerbilly
    Mar 20, 2005
    2,193
    Hamilton
    +94
    Really save up for a few month around 250 quid and then go on to the Canton power thread and buy a CD102 set of speakers. However you will also need an av amp.
    If you cant afford this then you may have to go for some all in one dvd player/speakers system.
  17. Corpsical
    Corpsical
    May 14, 2004
    506
    28
    Wales
    +78
    I'm sure you'll be over the moon with them, but be warned once you start down the Home Cinema path it soon gets quite expensive :)
    Enjoy your buy!
