105tommy105
Hi, i have just started playing battlefield 3 and get quite good frames but i get the odd drop in bigger areas, where it stays around 35-45fps i would like it to be high 50s, could someone recommend an upgrade:
CPU: AMD Phenom II x4 970 @4.0Ghz (Cooled with H70)
MB: GA-990XA-UD3
RAM: 8gb DDR3 @1700-2080Mhz ( Im not too sure theyre oc'ed with the cpu)
GPU: HD5870 [email protected] [email protected]
HDD: Solid state corsair 120gb Sata 3
Thanks in Advance
MB: GA-990XA-UD3
Thanks in Advance
