Want a surround system but.... Diagram
Discussion in 'Home Cinema Buying & Building' started by salfordred, Sep 7, 2005.
  1. salfordred
    salfordred
    Feb 2, 2005
    89
    My viewing seats will sit against a back wall in the room...... so will there be any problems with how the rear speakers will sound if they are almost directly above me.........
    [​IMG]
    If so.... can anybody tell me what I need to do to achieve surround sound, and what systems I can buy.
    My prefered option right now is the Pioneer DCS-340
  2. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Identical to my layout. It works fine if you can angle the rears in a bit it might be a bit .better. But I think you will be quite satisfied as it is.
    Jaymac
  3. salfordred
    salfordred
    Feb 2, 2005
    89
    Do you think that floor speakers may be better than wall mounted ?
  4. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Couldn't really say but if they are floor standing then your height is fixed. Wall mounted more choice.mines are about 2 ft. above ear level suits me but perhaps not everyone
    Jay
