Wana Mount Speakers On To My Wall.
Discussion in 'Home Cinema Speakers' started by Hysteria, Jun 6, 2004.
  1. Hysteria
    Hysteria
    Hi, I wana mount my sats on to my wall. I'm unsure what mounts to use. Thanks in advance.
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    I would guess that with those holes in the back of your speakers you don't need to buy any mounts for them, just use a couple of screws into the wall and hang the speakers on them.
    Mark.
  3. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I seem to be spending this week following Mark around and agreeing with him and it seems that I have to do it yet again.
  4. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    Don't worry Ian, I'm sure well find something to disagree over very soon :D
  5. Hysteria
    Hysteria
    Wouldn't there be unwanted vibrations?.
  6. Ian J
    Ian J
    Aug 6, 2001
    25,631
    +4,906
    I have my M&K K4 rear speakers mounted just like in your pic and there are no audible vibrations whatsoever
  7. Hysteria
    Hysteria
    Ok cool. See that gold threaded ring?, you recon thats for a pesific mount?.
  8. MarkE19
    MarkE19
    Aug 10, 2002
    17,486
    Rainham Essex
    +2,487
    If that gold ring is for a specific mount then I would suggest getting onto the web site of the manufacturer of your speakers (you haven't told us what they are) and see if they have the mount listed there. If not then I would guess that there is no specific mount - either their own or a third parties. But I would still suggest going for the screws in the wall method as I would think that it is going to be a lot cheaper than buying the mounts. If you don't like the results you can always buy the mounts at a later date.
    Mark.
  9. RumbleBee
    RumbleBee
    Apr 21, 2004
    138
    Teesside
    +6
    If those are the Pioneer S40's I use a screw and hang it on the higher hole. The only problem is they coccasional move left to right
  10. Hysteria
    Hysteria
    Yeah there sp40's, Could i use the second lower hole to counteract the swing?.
  11. RumbleBee
    RumbleBee
    Apr 21, 2004
    138
    Teesside
    +6
    I've never managed it, as you put the hole over the screw and move the speaker down to lock it in place. The lower hole goes to the left/right rather than down. Perhaps I slightly exagerated on the swing. My 2/3 settee is resting agains the cables and if the settee accidently moves the speaker does too.
  12. Hysteria
    Hysteria
    Alrite cool, Screw's it is then. Thanks for the help everbody.
