Walmart 360 wireless Problems
Munkey Boy
It has been put up before actually. The end of the story was that Walmart actually uses very old wireless technology that doesn't keep to it's bandwidth very well, so when anything trying to use part of that bandwidth also transmitted, the Walmart handheld scanners wouldn't work properly. MS helped Walmart tweak their scanners and this problem has now passed.
Essentially it was a Walmart problem though, not a 360 problem, so don't panic. You won't have any wireless kit as rubbish as the Walmart scanners are apparently as there are stricter standards for domestic products.
HSC
still strange though - as I thought the 360 booths only came with wired controllers.....guess there may not be a way of switching the radio off if you so choose
