Wallmounting Hitachi 32 PD3000
Discussion in 'Home Cinema Buying & Building' started by Ukkel1, Sep 27, 2004.
  1. Ukkel1
    Ukkel1
    Hi, i would like to wallmount my Hitachi 32PD3000 plasma screen. The manual doesnt mention at all whether this is possible and what i need to do. Is there someone who can explain what to do and what kind of wall bracket i need? The plasma needs to come a bit of the wall and i should be able to swivel it a bit.
    Many thanks
    Ener1
  2. AV Junky
    AV Junky
    Oct 30, 2002
    1,209
    Cheshire, UK
    +68
    Have a look at the plasma wall mounts on one of the dealers' websites. AV Sales for example (they advertise at the top of the forums pages) - they also have an offer on wall mounts over in the Special Offers forum.
  3. captaindobie
    captaindobie
    Apr 17, 2002
    579
    Scotland
    +17
    Wall mounting shouldn't be a problem. Hitachi usually do their own wall brackets. You can also check the following link. They have a handy feature on the website that allows you to check what wall bracket you need by inputting the make & model of LCD or Plasma that you have...
    www.vogels.com
    Then, all you need to do is find a dealer that sells these things at a reasonable price. :smoke:
