Wallmount brackets....Cheapest place
Discussion in 'Home Cinema Buying & Building' started by nealgs, Oct 21, 2003.
  1. nealgs
    nealgs
    Hi all,
    Will be joining the land of Plasma very shortly:smashin: and will need a wallmount to erm, wall mount the plasma
    Anyone know the cheapest place to purchase one from, also some component cables required as well good quality at good prices please
    connecting the following, hopefully via the component switching from the Yamaha RXV1000RDS receiver
    dvd->sky->jst rgb-yuv->amp->|
    ____________________________|-->plasma
    xbox (at some point)->amp-->|
    cheers
    Gary
  2. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    check out www.av-sales.com - delivery free too...(seem as cheap as any other sites and they use these forums)
  3. nealgs
    nealgs
    Cheers Jasonjo - just noticed a powerbuys on them too :)
    oh yes Wooohooo my 100th post :)
    Gary
  4. jmack
    jmack
    depending on what plasma you get ? they do pop up on ebay now and then
    i think there is a panny mount on there now. or was a few days ago
  5. nealgs
    nealgs
    Hi jmack
    plasma will be the Pioneer 433MXE, will keep a lookout on Ebay - cheers
    Gary
  6. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    nealgs - what plaz you going for then??? ;)
    JJ
  7. jmack
    jmack
  8. Mr THX
    Mr THX
    Nov 26, 2002
    1,309
    Barnsley
    +32
    jmack
    Just bought one of these myself, can recommend Paul the trader highly. Excellent contact and goods arrived in no time at all. I bought it on 'buy it now' so paid £65 but is well worth it. Panny PW6 went up on wall last night and looks superb. Bracket can be fixed in the straight vetical position or slightly tilted down (If placed above fireplace maybe?) either way bracket is well made and well worth the money.
  9. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    nealgs, have a look at the post (plasma wall brackets!!!!bargain??)
    ASH1 :smashin:
  10. nealgs
    nealgs
    Thanks for heads up ASH1 - can't believe i didn't say thanks till now:suicide: :blush:
    Works out about £76 or so for stud partition bracket and plasma mount, or £18+vat less for brick wall bracket and plasma mounts
    good price, will give em a call tomorrow and see if suitable for the MXE
    Hows the 400E going? everything installed yet?
    regards
    Gary
  11. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Hi nealgs, Almost there. I have to take the screen back down, it's a little to high about 6" to 8". Had a quick look at my 3800 going through it and I've had this stupid grin on my face ever since. :D All the best setting up your MXE.
    Jasonjo, does the 3800 have a screen saver mode?
    Will try and post picture when it's all set up, if I can work out how to do it.
    ASH1 :)
  12. nealgs
    nealgs
    ASH1,
    How hi up you got yours To the bottom of the screen? am trying to work out the best location (given that we may get a fireplace at some point to) so looking at around 50-52inches to bottom of screen
    cheers
    Gary
  13. Jasonjo
    Jasonjo
    Dec 3, 2001
    2,677
    UK
    +115
    ASH1...
    screensaver...nah not really, you can choose a wallpaper colour or the Denon picture, thays about it :(
    auto-power off mode is possible if this helps...(30 mins)
    JJ
    P.S. You could insert a picture CD and use the slide show option though...
  14. ASH1
    ASH1
    Mar 1, 2003
    1,221
    +63
    Hi nealgs, I'll PM you.
