Wall / Special stand mount on Hitachi 42PD7500 ?
Discussion in 'Home Cinema Buying & Building' started by grouzy, Oct 15, 2005.
  1. grouzy
    grouzy
    Hello
    I just bought a 42PD7500 with an Alphason ADP3/96S TV stand (where you can fix the screen like a wall mount), but I'm a very beginner in this, and I don't understand where on the screen side it should be fixed.
    I can see lots of screws, but not sure they are all made to support the screen weight.. Nothing is written in the doc for this. Does someone know where the mount should be fixed on this screen ?
    thanks
