Wall Speakers
Discussion in 'Home Cinema Speakers' started by pcpaz, Dec 30, 2002.
  1. pcpaz
    pcpaz
    I am currently re-designing my living room and looking at the possiblity of embedding some speakers to two corners of the room. At first I was just going to purchase some tower floor speakers and put them either side of the TV, but I think the speakers in the corner of the room will be more visually appealing and hopefully provide a better result.
    My main question is do I buy separate speakers and then connect them together before fixing them to the wall, or do I just but a pair of tower speakers, take the front apart and fix this to the wall.
    Another question how is easy is it to wire up a speaker system as you can probably tell I have never done this before.
    Any help would be great.
