wall/shelf mounting AE Evo 1s
Discussion in 'Home Cinema Speakers' started by mike_cummi, May 10, 2005.
  1. mike_cummi
    mike_cummi
    Anyone done this? If so, what have you used and what were the results?
    I'm thinking of making my own simple mounting shelves out of heavy duty brackets and a sheet of thick MDF, perhaps 18 inches wide so that I can get the speakers as far as possible away from the wall. I am a bit worried by the fact that they are rear ported and even though AE website says they are designed for stand/shelf mounting I am worried about the rear port and proximity to the wall.
    Grateful for any feedback.
  2. mike_cummi
    mike_cummi
    No one has wall/shelf mounted Evo 1s? :lease:
  3. dashfield
    dashfield
    Jan 1, 2006
    624
    +27
    What did you do about this in the end? I am in the same situation and don't know what to do about mounting these speakers.
    Any advice would be greatly appreciated.
