Wall plates and Subwoofer cables
Discussion in 'Home Cinema Building DIY' started by matblack, May 9, 2005.
  1. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Anyone run a sub cable between faceplates, I need to do this but all the faceplate connectors I have seen are solder on the back ones and not back to back RCA sockets so I can't use a pre-made cable. I'd ideally like to use shielded cable as my sub has a tendency to hum to itself but this my be better in the cellar.
    What to we think of using CT100?
    MB
  2. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,545
    Near London.
    +208
    You could get a blank wall plate and mount a phono coupler onto it yourself, CPC product code CN05878 would do exactly what you're after. Alternatively you could solder some sockets onto a panel yourself. :)
  3. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    My wall plate
    [​IMG]
    Wall plate on the left.
    I used MK std face plate and drilled the relevant holes for the sub and rear speakers. Connectors brought from Maplins and cost about £10 to make.
    I can take a better picture if you want.
  4. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Thanks for that
    I'm pretty happy with making the faceplates, I'm doing loads of 4mm ones and I'll do a couple of F connector ones to. What I was really interested in is what you were running between the faceplace, what cable did you use?
    MB
  5. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    For the speakers I used some Gale speaker cable and for the sub I used some high quality shielded sub cable.
    Best to use quality cables. Also do a dry run before the cables are hidden for good.
  6. matblack
    matblack
    Jul 30, 2003
    406
    +10
    Can you tell me where you got the sub cable and how you terminated the shielding on the cable too? :lease:
    MB
  7. Vinesh
    Vinesh
    Dec 23, 2002
    776
    28
    +31
    I already had the sub cable from my old house. Any good hi-fi retailer should sell sub cable by the metre.
    The wire was soldered to the connector.
