wall or stand mount?
Discussion in 'Home Cinema Speakers' started by peter76, Oct 15, 2004.
  1. peter76
    peter76
    Generally, is it better to wall or stand mount speakers? Common sense tells me it's wherever can provide the sturdiest platform which would probably be stands, but really is there much of a difference?
    I have a pair of B&W DM303 and am thinking due to space constraints about mounting them on the wall. If they're going to sound rubbish, however, I'll have to think of something else... Any views?
  2. dj_johnnyg
    dj_johnnyg
    Personally I prefer to wall mount my speakers.
    Just don't scrimp on the cost of the brackets, and make sure they are really tight against the wall, to stop them rattling with the bass.
