nheather
Outstanding Member
I have a LG 65” OLED to hang on the wall. Plenty of wall support as it previously held a much heavier 55” plasma.
So I need a wall mount - what are the recommendations. I can see ones in eBay for £15 or less, I can see Richer Sounds trying to flig me a ‘basic’ one at £70. And I can see plenty in between and higher. But the basic designs all look similar.
Basically, I just want it to sit flat on the wall, no tilting and reasonably low profile.
Is there any reason why I should not be looking at the lower end - I’m struggling to see what extra I get by paying more.
Another question.
My TV has a rectangular VESA fixing 300 x 200
When I look at many of the mounts on sale they don’t include this VESA specification. But this puzzles me, one which uses the standard design of two fixing bars hanging from a rail states that it supports
Cheers,
Nigel
Another question.
- 100mm x 100mm
- 200mm x 100mm
- 200mm x 200mm
- 300mm x 300mm
- 300mm x 400mm
- 400mm x 200mm
- 400mm x 400mm
- 600mm x 400mm
Cheers,
Nigel
