Wall Mounts - Advice Needed
Discussion in 'Home Cinema Buying & Building' started by nheather, Oct 15, 2004.
  1. nheather
    nheather
    Oct 6, 2004
    17,586
    167
    Horsham, West Sussex
    +6,986
    I plan to get a Pany PW6/7 and would like to mount it on the wall so it looks more or less like a picture frame.
    Most of the mounts that I have seen in the flesh have been the tilting type which result in the panel hanging a few inches off the wall.
    I want mine to be flat on the wall - what is the best way to do this:
    (i) I've seen low profile mounts advertised - how far do these leave the panel from the wall?
    (ii) Would it be better to fix the mount in a recess in the wall so that the panel sits flush against the wall - nice idea but I can't see how you would be able to fit and lock the plasma onto the mount - is there such a thing as a telescopic mount, fit the plasma away from the wall and then push back so its sits flush
    (iii) Are there any cooling/ventilation issues
    I would appreciate any advice or pointers to useful websites or books.
    Cheers,
    Nigel
  2. sabujo
    sabujo
    i) the most common distance is 6.5 cm for non-tiltable versions.
    ii) you'll probably not need it anyway. take a look at Vogel's plasma wall mounts, for instance (model 2001, I believe). They come in two pieces: you secure the base on the wall and the frame on the plasma; Then, just slide one piece over the other and you're done.
    iii) as long as u don't recess the wall mount into the wall itself, you should be fine.
  3. Member 45084
    Member 45084
    Oct 7, 2004
    80
    11
    +11
    Have a look at the model at www.rs100.co.uk
    This fits almost all Plasma screens and is as flat as possible.
  4. lynx
    lynx
    Jan 20, 2002
    4,651
    It always rains.
    +302
  5. 1_crazy_mofo
    1_crazy_mofo
    Hi i have seen lots of flush mounts on ebay.co.uk in plasma section new and secondhand from about£ 40 upwards .
