Wall mounting
Discussion in 'Home Cinema Buying & Building' started by Laskina, Jan 17, 2003.
  1. Laskina
    Laskina
    Would you recommend wall mounting a 42" plasma yourself or get an expert in? DIY saves me £300!
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,436
    Newcastle
    +272
    There's been some discussion already on how to do this - try doing a search in this forum.
    Cheers,
    Liam
  3. TheBigApple
    TheBigApple
    Dec 10, 2002
    665
    In my cage
    +13
    Depends. Can you put up a shelf. If you can you should have no trouble with a plasma.
  4. Nick23
    Nick23
    Feb 25, 2002
    121
    16
    Depends if you have the confidence in your ability. Is it really worth it, after all you are actually "hanging" a £3000+ piece of electronics on the wall that will break if if falls. Its probably a good idea to double check there aren't any electric cables behind the wall you are planning to put it on as well as it might cause interference... and could also give you a nasty shock when you drill into it.
    Peace of mind is priceless.....
  5. installer09
    installer09
    Aug 26, 2002
    415
    16
    SWINDON ,WILTS
    I will do it for£299 if you are local :D
