stingray1906
After finally fixing my first set to the wall (40" size). I would like to know if there is a web site where you can get all the dimensions of auxiluary sockets/connections on the back of your TV. A guide that helps where to pre drill the holes required to bring HDMI / MAINS cable etc straight out into the back of the TV. My first attempt meant i had to bring the HDMI cable out of the wall and the HDMI socket was about 8" away. Any tips on pre planning the correct location and layout would be appreciated.
