Wall mounting the Panasonic TH42PV500
Discussion in 'Home Cinema Buying & Building' started by ClumsyBiker, Jun 1, 2005.
  1. ClumsyBiker
    ClumsyBiker
    Would I be right that the panasonic order code "TH42PV500B" means the TV with no wall bracket?
    If so, I would like recommendations for a wall mount for this unit, preferably a retailer who can deliver within 2-3 working days. At the moment I'm looking at the AV-Sales slimline mount at £125- they say that the Viera PE30/50B needs the extra £20 extension kit, but the PV500 does not.
    Can anyone confirm the above (especially about the extension kit), or recommend a good bracket to suit the PV500?
    Thanks :thumbsup:
  2. ClumsyBiker
    ClumsyBiker
    As an addendum to the previous post: I've ordered the slimline bracket from AV-Sales and one of their staff has just phoned me to query me order re: the £20 Viera extension bracket.
    Apparently his colleague was incorrect in advising me, and now I DO need this extension. (Makes sense considering all the new Vieras seem to have that large plastic cowl covering the inputs on the rear of the set)
    AV-Sales dropped the ball a little there :oops: , but at least recovered in time so I won't be disappointed when the unit arrives next week!
    Roll on delivery.
  3. nijhar
    nijhar
    May 26, 2005
    7
    i have done alot of research into mounts and have found:
    http://www.rlsupplies.co.uk/
    the cheapest around. They are based in watford. you can get stuff delivered or pick up from them. the best mounts are probably the Vogels brand. i am about to order all my mounts and accessories from them soon.
    hope this helps...
    Nij
