Wall mounting the 9986
Discussion in 'Home Cinema Buying & Building' started by Car man sleeps, Feb 8, 2005.
  1. Car man sleeps
    Car man sleeps
    Another week yet before JL can deliver my 9986...can't wait!
    I assume the wall mount it comes with is fixed...so, what if you want to tilt / swivel the thing? Has anyone out there done this?
    Car man
  2. garytreble
    garytreble
    Feb 3, 2005
    126
    +13
    Yes, the wall mount and stand is included in the standard package. I'm still waiting for mine to be delivered from empire..
  3. rnsdm001
    rnsdm001
  4. Car man sleeps
    Car man sleeps
    thanks, I might try that one
    looks like it might leave the screen a long way from the wall though??
    Car man
  5. Wizz
    Wizz
    Just wall mounted mine in a corner. Took the plunge after no responses to an earlier post. Got it from Unbeatable @£289 and arrived next day - pretty impressive!
    Dead easy to fit, just make sure you've got something solid to fix against given the weight. Thinking about getting the trunking accessories to finish the job now.....
    Very impressed with it and does everything I wanted.
