wall mounting & surround sound on LGPX11
Discussion in 'Home Cinema Buying & Building' started by paulyh, Apr 4, 2005.
  1. paulyh
    paulyh
    I was wondering if someone could help me, I have just bought an LGR242PX11 and want to have it wall mounted on to a wall which I think is made of breeze blocks.
    1. Can you recommend anybody in the Oxfordshire area who would be able to do this for me.
    2. Can you recommend the type of wall mounting kit I require
    3. Can you recommend a 'relatively cheap' surround sound system that would complement the TV.
    4. The satellite system/DVD player that I have will probably be further away from the TV than the standard leads would allow, is there anything that can be done about this.
    As you can probably tell I am a complete novice so any sort of input would be great.
    thanks
  2. Ross-P
    Ross-P
    Mar 16, 2005
    399
    UK
    +25
    I ( and others ) could suggest a few all in one surround systems if you give me a rough price you want to pay :)
