Wall Mounting Speakers
Discussion in 'Home Cinema Speakers' started by Rasczak, Jan 18, 2003.
  1. Rasczak
    Rasczak
    Apr 3, 2002
    21,146
    Argyll
    +2,208
    I'm on the verge of investing in a surround sound system using a Denon 3802/3 and B&W DM300 series speakers (2 x B&W DM309 Floorstands, 2 x B&W DM303 Rears, 1 x B&W LCR3 and B&W ASW 300 Subwoofer).
    My question relates to the rears - I am very keen to have these wall mounted. However a quick look round suggests that the type of installation can have an effect on sound quality. Will installing these rear speakers with cheap 'Speaker Wall Mounts' such as £20 ones from Argos be a bad move or should I be looking at specifically designed AV ones. I'm not against spending money on the brackets but, obviously, only want to if it's actually worth it.
  2. coolposter
    coolposter
