Quantcast
Wall mounting Speaker brackets
L
leesbriggs
Hi all, I'm after some speaker brackets for my sony hifi speakers. I don't want to be able to see the bracket though, so I need something that screws into the back of the speaker. I noticed that Argos do something that I'm after HERE but they only support upto 5KG. I would say that mine are about 8-10KG. Any ideas would be appreciated. Cheers.
L
lfmaguire
Mission do some for their Mission 70 bookshelf speakers. The speakers only weight a couple of kilos each but the bracket is sturdy ABS and screws into holes already in the back of the enclosure. You could always use self tapping screws though.
They also have a "fly-wheel" to tighten the ball joint so you can point your speakers where you like. I guess your limitation is just the weight.
