Wall mounting Sony KE42TS2E
Discussion in 'Home Cinema Buying & Building' started by Tim487, Jul 27, 2005.
  1. Tim487
    Tim487
    Has anyone wall mounted this screen using a non Sony wall mount, there are some 8mm screws at the rear of the screen, but these seem much too flimsy. Can anyone help me please?
  2. lpussykat
    lpussykat
    The screwholes on the back are fine, they look very flimsy but mine has been mounted for 2 years an its ok, Steve liverpool,:clap:
  3. lpussykat
    lpussykat
    try this web site if you have any problems its dedicated to sony enthusiasts,
    www.agoraquest.com, its like this site but has a lot of good info,I am looking for the base stand for the ke42ts2e at the moment but have had no joy at the moment ive just taken mine of the wall, have it propped up with 2 big cushions, HOPE THIS HELPS, STEVE LIVERPOOL:clap:
