Maverick567
Established Member
I am looking at trying to wall mount a small no more than a 6kg TV on a bedroom wall. I understand that the ideal is two mount onto studs however the building is metal stud work and the wall I want to mount it on is only 30 inches wide so there is limited mounting locations. There is already all wiring installed in the wall at 1.5 meters.
Would a standard tilt mount be suitable with specific plasterboard fixings like grippit or toggler given the limited amount of wait being used.
I think the house has 15 mm plasterboard throughout.
