Wall-mounting Samsung JS9000 - which M8 screw length?
Discussion in 'Home Cinema Buying & Building' started by PK13, Jul 12, 2015.
  1. PK13
    PK13
    Apr 10, 2013
    3
    Am looking at wall-mounting a Samsung UE48JS9000 on an AVF4701 bracket. The wall mount includes various screws but longest M8 diameter is 25mm. In the Samsung manual it specifies 32-40mm. Would the 25mm ones do the job (is length also mount-specific), or do I need to get longer ones. Any tips much appreciated.
    PK13
