Wall mounting Quad L-ites
Discussion in 'Home Cinema Speakers' started by The Prophet, Mar 16, 2006.
  1. The Prophet
    The Prophet
    Just recieved my Quad L-ites. What's the best way to wall mount them?
  2. PercyP
    PercyP
    Dec 6, 2005
    71
    Woking
    Prophet, did you get any response to this? Or what did you end up doing?
    Cheers,
    P.
  3. The Prophet
    The Prophet
  4. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
  5. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
  6. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    I think the Quads deserve better (nicer) brackets than the ones posted so far (sorry guys).
    I will be picking up my Quad L-ite package next weekend, then I'll post my suggestion (must check the screw fixture properly)
  7. PercyP
    PercyP
    Dec 6, 2005
    71
    Woking
    MaiaMan,
    I noticed on another post that you are testing this package at home for 15 days. Could I ask which dealer you got this test-drive through? Did they offer any special deals on the speakers?
    Cheers, P.
  8. The Prophet
    The Prophet
    MaiaMan, what did you do?
  9. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    Well guys, I live in Portugal. Over here you can hand back some types of goods (hifi for example) within 15 days of the purchase, if you're not satisfied. No questions asked (supposedly, I've never done it). So I'm trying out the Quads risk free.
    Now about the mounting... the speakers have a single screw at the back. I think they're too delicate to mount on stands, especially with kids at home. I had the idea of getting a rectangular piece of perspex, drill a hole in the center to mount the speaker and four holes in the corners to mount the perspex on the wall.
    I'm open to opinions and sugestions.
    Can anyone tell me how to attach a pic? I've gone to Manage Attachments, uploaded the pic, then what?
  10. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    OK, I see how it works.
  11. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Maiaman,
    You can get Omnimount or other wall mount brackets for them here in Portugal...
    Drop by here... ;) : http://forumhifi.com
  12. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    Is the silver thing a screw hole at top rear?
  13. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    The fact there is a threaded tap in the speaker suggests Quad have something in mind. Has anybody tried E-mailing Quad to see what?
    Russell
  14. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    :confused: :confused: :confused:
  15. Member 96948
    Member 96948
    Nov 18, 2005
    10,238
    The Fen Edge
    +2,253
    Quad wouldn't put a threaded hole in the back of the speaker unless it had a use. E-mail them to see what fits in it. It might be a wall mount. Their website is crap, so it may not be well known.
    Just a suggestion
    Russell
  16. Falp
    Falp
    Apr 23, 2004
    1,685
    48
    Lisbon
    Of course it's a wall mount... they are wall mountable satellite speakers...:cool:
  17. The Prophet
    The Prophet
    The suggestion I got directly from Quad was http://www.b-tech-int.com/BT33.htm
  18. WSH
    WSH
    Apr 13, 2002
    1,014
    48
    +39
    It doesn't look like they go up or down, just side to side. :(
  19. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    Olá FALP:smashin:. Já conheço esse forúm, obrigado. (Just a little greeting in portuguese)
  20. tc08
    tc08
    How about Vogels VLB50?
    You can move them in all directions but since the L-ite is so big, and the screw is so high up the movement will be pretty limited, unless perhaps you put something behind the mount to distance it a bit more from the wall.
    They are pretty cheap, seen them for €17 a pair here in Stockholm.
    Now do you goys know of a nice stand for the L-ites, I don't want my front speakers to be wall mounted since I have the room for a pair of nice stands, and it looks good. But I just can't find stands where the plate to place the speaker on is small enough... (135x180 mm)
  21. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
  22. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    746
    43
    +177
    They can go up and down.
  23. Jules Tohpipi
    Jules Tohpipi
    Feb 4, 2004
    746
    43
    +177
    Give Apollo a call. They do some stands at a reasonable price with a top-plate ideal for the L-ites. And there's a lacquer option too, to match the finish on the Quads.
  24. sjackson
    sjackson
    Jan 8, 2006
    2,189
    116
    Ireland
    +539
    I went for the B-Tech BT77 speaker mounts instead of the BT33's. I think they look far nicer (maybe I'm just into that look).
    Anyway - I got them for £20 a pair of ebay. Been emailing the seller for a few days, and he's very good to answer questions.
    I'll put up photos when they arrive.
    http://www.b-tech-int.com/BT77.html
  25. tc08
    tc08
  26. MaiaMan
    MaiaMan
    Feb 13, 2006
    146
    With direct sunlight this photo would come out better, but still here is what the Quads look like on a stand.
  27. tc08
    tc08
    That is a nice stand but I want someting "lighter" to make the speaker stand out, really. I have found a stand at IKEA that seems reasonably stable and very cheap, like £19, which I will try to modify a bit later today, will get back with pics :)
  28. mavice
    mavice
    Dec 8, 2004
    400
    Devon UK
    +16
    :rolleyes: Anyone know he weight of the sats ??
    important when choosing wall mounts !!
    seems any specs online only seem to show weight of the sub ?
