Wall mounting pv 500
Discussion in 'Home Cinema Buying & Building' started by 2005, Jun 21, 2005.
  1. 2005
    2005
    Is it possible to plug all the leads and scarts when its wall mounted (non tilting, pannys own) or whats the best way to hook it up.
    Cheers,
    C.
  2. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,063
    2
    4
    137
    Garstang, Lancs
    +1,597
    I have the wall mount that I got with mine from RGB direct, and beacuse this is set on 2 bars you can hook it just on the top one and tilt it far enough to get your leads in, but you need a couple of friends.
