Wall mounting plasma's over a fire place?
Discussion in 'Home Cinema Buying & Building' started by mph8873, Nov 6, 2005.
  1. mph8873
    mph8873
    Nov 28, 2003
    75
    Hi guys,
    This may sound like a totally stupid question, but.... is it ok to wall mount a plasma over a fire place?
    I have an open gas fireplace and simply assumed that it would be a stupid place to put the screen because of the heat coming from the fire but I've seen a few threads where people are doing just that. Does that mean it is ok, or does it mean that they are just making the fireplace redundant?
    It's the only place I can get away with wall mounting otherwise I will need to opt for a cabinet.
  2. SteveG
    SteveG
    Jan 14, 2003
    1,041
    London, UK
    +92
    Have a search, plenty of threads on this topic like this one. Personally I wouldn't unless you don't plan on using the fire much.
  3. Faust
    Faust
    Dec 21, 2002
    3,535
    UK
    +768
    It is also a pretty unnatural height to watch t.v. at - the usual recommendation is to watch either at just below or at eye line when seated. Personally I would not like to be sat looking up at my t.v. all evening. I'm sure those who have mounted their t.v.s at a higher level will immediately post to defend their decision, however, the height recommendation has been tested scientifically and is not one I have made, but is one that I wholeheartedly agree with.
  4. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Personally I think it is all down to personal preference and space/circumstances. We have our plasma above the fireplace, which we checked to ensure there wasn't going to be excessive amounts of heat.
    We have no problem with the viewing height at all, others may have but thats just us. We wished to increase space and remove clutter from our living room so we went for the wall mounting and windows mce from our pc in another room. All we have in the living room now is the plasma and surround sound system.
  5. dando
    dando
    We have ours above the fireplace and its perfect viewing. I believe, as I have said before, I dont see the point of buying plasma if u dont wall mount them. I also think that they are designed, first and foremost, for watching films and when you go to the cinema, the screen is set slightly higher than eye level.
  6. UKseless1
    UKseless1
    Mar 9, 2005
    842
    28
    +36
    MPH - only responding cos you've had 2 that have responded nay!
    If you are a free thinking person who has come here to find out all your options and you don't mind going against the scientifically tested recommendation. Switch the fire on and use a thermometer to decide if really does get too hot above your fireplace and decide for yourself which route you'd like to take.
    If you think it will be too neck jarring then test this by using a cardboard cutout that is similar in size to your intended screen and place it at various positions.
  7. UKseless1
    UKseless1
    Mar 9, 2005
    842
    28
    +36
    Well there you go, I didn't need to respond, you go 2 for and 2 against :)
  8. dodgyd
    dodgyd
    Jul 8, 2005
    848
    +83
    We were able to build our fireplace (height and width) for the specific purpose of installing the plasma above. The plasma is higher than it would be if it was on a conventional floor stand, but it doesn't look too high and hasn't created any problems (with our necks or heat related ;) ) in the couple of months it's been in place.
    I can post picture if you want, but it's essentially an inglenook 'style' fireplace (deep and wide) with a coal effect (gas) fire within.
    Good luck, at least you're doing your research :)
    Dave.
  9. Faust
    Faust
    Dec 21, 2002
    3,535
    UK
    +768
    Well it might be in the cheap seats, but not from where I sit in my local cinema it isn't :D . Apparently it is all to do with how the eye focuses, and if you are looking up then the eye is optimised for distance and not for viewing t.v. etc.
  10. paddeo
    paddeo
    Nov 6, 2005
    56
    Fossil and Dando,
    What height, from the floor, are your plasmas mounted?
    Pat
  11. Fossil
    Fossil
    May 29, 2005
    105
    +5
    Ours is 1.4m from the floor.
  12. mal60908
    mal60908
    Bottom of mine 1.1m from floor, click on PV500 in my signature for pics.
  13. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    I have mine mounted above the fireplace because I tend to slouch on the sofa. I actually found it uncomfortable watching the old CRT when it was on the stand on the floor! Purely a personal preference though.
