P
Pids
Has anyone wall mounted the MS bi-pola speakers? If so how did you do it.
Are there any special fixings. Or is it just a screw in the wall?
Oh yeh do I need to position them facing each other on side walls, or can they be on the back wall behind the sofa facing the TV?
Any help aways noted. Many thanks.
