Wall mounting M&K 55 MkII & 550THX speakers.
Discussion in 'Home Cinema Speakers' started by Glenn Keen, Mar 25, 2006.
  1. Glenn Keen
    Glenn Keen
    Apr 30, 2004
    159
    Roos, Nr. Hull
    +8
    I finaly moving to a house where I can set up my home theater room and I'm looking to mount me M&K Speaker properly.
    I'm in need of a bit of advice on speaker stands & wall brackets that might be suitable for my M&K speakers.
    The setup is currently as follows:-
    *=Speaker.
    -------------------------------PLASMA
    M&K 55 MKII(left)----¦------M&K 55 MKII (Centre)--------M&K 55MKII(right)
    --------------M&K VX-7 MKII Sub
    M&K 55 Tripole(left surround)-----------------------------M&K 55 Tripole(right surround)
    -------------M&K 550THX (surround)-------M&K 550THX (Surround)
    I'm wanting to wall mount the 4 surround speakers (all appear to have the same mounting points on them), and put the front left & right on stands. Not sure what to do with the centre.
    So any advice on suitable mounts & stands would GREATLY be appreciated.
    Thanks in advance.
  2. zero7
    zero7
    Feb 19, 2004
    822
    3
    Warwick
    +77
    If it's any help I will be mounting my SS-150's using the brackets they come with on the wall's at about head height.
  3. Glenn Keen
    Glenn Keen
    Apr 30, 2004
    159
    Roos, Nr. Hull
    +8
    Hm.. can't remember mine coming with brakets, but it was a long time ago. I'll have to check the boxes in the loft.
    And Zero7, your sig line used to be my email sig line for over 10 years!
    Save Ferris! :)
