Wall Mounting LG RZ15LA32?
Discussion in 'Home Cinema Buying & Building' started by marksol, Dec 11, 2003.
  1. marksol
    marksol
    I notice this model does not support standard 75mm or 100mm wall mounting brackets.
    The vertical sockets are set at 100mm pitch and horizontally at 128mm.
    Can anyone please advise where i can get a wall mounting bracket to fit.
    Thanks in advance - s
  2. bobbypunk
    bobbypunk
    contact vogels to find out if they sell an adaptor and if they do find one of their many dealers
    www.vogels.com for contact info
  3. ASH1
    ASH1
    Mar 1, 2003
    1,217
    +62
    The bracket I bought from RS says it's compatible with LG's
    ASH1
  4. marksol
    marksol
    Thanks for your suggestions.
    I eventually found and ordered an LG manufactured wall mounting bracket for this model at £65 + £7 p&p from Unbeatable.co.uk.
    Extremely poor value given the limitations of this bracket (up/down tilt only) no left/right or swivel adjustments.
    A poor show by LG who should allow standard VESA brackets to be fitted rather than their own custom model.
  5. midknight
    midknight
    Oct 8, 2000
    4,592
    Billingshurst, West Sussex
    +1,342
    Is the LG any good ?
  6. marksol
    marksol
    Yes it is good.
    Certainly in terms of value for money. At the time of buying a few months ago (£399 from Curry's) it was the best sub £500 box I could find.
    I have it installed in my bedroom where it is connected via iLink to Sky box.
    Picture quality is more than adequate for bedroom viewing which consists mainly of Sky News and the occasional football match.
    s
  7. marksol
    marksol
    Yes it is good.
    s
  8. midknight
    midknight
    Oct 8, 2000
    4,592
    +1,342
    Thanks - just ordered one
