Wall mounting LG 47lm6700 to a new plaster wall
Discussion in 'Home Cinema Buying & Building' started by Kdyman, Aug 21, 2013.
  1. Kdyman
    Kdyman
    Aug 21, 2013
    This may be a dream situation for some people but I don’t know where to begin
    I have a 47” LG TV which I want to mount on the wall
    Here is the bit I think is good news, while the wall are plaster covered brick it is about to be knocked back to brickwork to treat it for damp.
    Is it possible to fit some kind of channel to the wall to run cables through prior to it been re-plastered? If so what would I use to form the channel? What would be the best way to go about this?
    Alternative would I be better use trunking on the surface of the wall?
    Finally how long should I wait to mount the TV and a floating shelf (for Sky Box) on new plaster?
    If it helps the cables need are
    2 power cables (TV and to Sky Box)
    2 Cat6 Ethernet Cables (for smart TV and Sky Box)
    2 or 3 HDMI Cables
    1 Dual feed coaxial sky cable
    1 Telephone Cable for Sky Box
