wall mounting Kef Eggs
Discussion in 'Home Cinema Building DIY' started by IGADHIA, Feb 19, 2003.
  1. IGADHIA
    IGADHIA
    Hi there, I am looking to wall mount the eggs. I have a 'hollow' wall ie, cement boards.
    How would I go about putting these up, what to the wall mount fittings look like of these eggs?
    thanks for any help you can provide.
    Ash
  2. derekrcross
    derekrcross
    Feb 20, 2001
    442
    19
    hi the keff stands are wall mounts also. The screw spacing is the same as a standard 1 gang electrical back box so you could cut out dry lining boxes run the speaker cable through these and to the eggs and from experiance thay hold well
    hope this helps
