Wall mounting - Hitachi
Discussion in 'Home Cinema Buying & Building' started by Perplexed2005, Sep 24, 2005.
  1. Perplexed2005
    Perplexed2005
    Probably a simple question, but beyond my limited knowledge...
    I've got a 42" Hitachi plasma that weighs 35kg and I have a universal wall mount bracket.
    BUT, as far as I can tell using my stud detector, I've only got 20mm thick plasterboard that I can attach the plasma to.
    Is this enough to support the plasma?? My gut feeling is that it's not.
  2. Badger0-0
    Badger0-0
    May 30, 2005
    20,593
    Spaghetti Junction (really)
    +1,921
    If it is 20mm, I'd say yes, with the right fixings (big plasterboard butterfly ones and ideally 4 of them).
    Normal 12mm plasterboard, I wouldn't recommend it.
    No personal experience of wall mounting plasmas, but I'm a pipe fitter who does fix stuff to plasterboard occasionally.
