Wall mounting Hitachi PD6600
Discussion in 'Home Cinema Buying & Building' started by Sharpy14, Sep 18, 2005.
  1. Sharpy14
    Sharpy14
    Has anyone managed to wallmount one of these, and if so, which screws did you take out the back in order to attach the vertical bars. I assume the vertical bars should attach to the indented vertical strips on the tv, but there are no instructions I can see with the telly.
    There is a large screw at the top of each vertical, then two smaller ones, then the supplied stand
    Any help welcome
  2. john.williams58
    john.williams58
    Aug 31, 2005
    I Wallmounted (above My Fireplace) My Hitachi 6600 Using The Slimline Wall Universal Mounting Bracket From Av-sales.
    The Men Who Delivered The Plasma,explained That You Only Needed To Secure The Plasma By The Two Top Bolts,as They Have Wall Mounted Many By That Method,
    So After Removing The Stand I Undid The Top Two Bolts,removed The Plastic "lugs" And Re-screwed The Bolts Through The "two Bars" Which Were To Connect To The Back Of The Plasma,and Onto The Wall Mount,in Doing So Two Of The Lower Smaller Screws,also Lined Up With The Two Arms So I Unscrewed Those, Their Screw Heads Were Small For The "slots In The Bars So I Put Washers With Both So They Would Hold Against The Bars And Re-screwed Them Through The Two Bars,result...each Bar Has Two Screws Too Each.
    Job Done
