Wall Mounting For Sony KDL-V32A12U ??
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by dobermann, Mar 16, 2006.
  1. dobermann
    dobermann
    What wall mounting bracket would you recommend for a Sony KDL-V32A12U 32" LCD TV?
    The one Sony are offering to go with the TV seems to be a bit expensive.
    Thanks.
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    If I remember correctly, the new Sony's do work with a VESA 100x200 bracket or a 200x200.
    If I get chance I'll check for you tomorrow.
    Chris
  3. simon_marshall
    simon_marshall
    I'd be interested to know this as well - just started researching wall mounts for the sony bravia....
    cheers,
    Simon
  4. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
  5. alpina
    alpina
  6. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    Julie how much for this mount ?
  7. alpina
    alpina
    think it was about AUS$120.00
    julie
  8. iendicott
    iendicott
    May 3, 2005
    268
    Peterborough
    +5
    The mount I found came to £52.99 + pnp but you can't adjust the angle unlike that one.
  9. alpina
    alpina
    true, i think the one we got is tiltable but with a spacer.
    we chose this one because its so thin and didn't need to tilt. hard to explain by our lcd hides in our wardrobe and we dont have a lot of clearance from door to lcd. for this reason, this particular mount was perfect! :)
    cheers,
    julie
