Wall Mounting For Samsung LE32R41BDX
Discussion in 'AV Stands, Cabinets, Seating & Furniture' started by bwfc0907, Mar 13, 2006.
  1. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    I'm thinking of this Premier Mount AM2
    http://www.theplasmacentre.com/prod...5&shopsessid=6277d81e718d1b4eae75ba9412993245
    but seems a bit pricey £89 when including the adaptor plate £22 on top. Money is tight but I want the right mount.
    Anybody know where they are selling it in the UK cheaper? Have seen that http://www.konnect2.net/ site but am unsure of cost or how to order. Can anybody help with the price on the site and how I do order.
    Also found this http://cgi.ebay.co.uk/LCD-TV-Wall-M...itemZ5877945616QQcategoryZ48656QQcmdZViewItem
    Any thoughts would be appreciated.
  2. vex
    vex
    Mar 8, 2005
    2,905
    103
    London, Home Counties & North West
    +261
    We have our 32" Samsung LCD hung off one of these, works great but you dont need the additional 200x200 adaptor.
    One word of caution, the thread widths are different to what is supplied, I had to drill the plate out a little to accomerdate them.
    If you contact the installer most local to you on the Konnect2 'where2buy' page they will be able to supply to you.
    We have them in stock and could get it to you for Wednesday, £89.00 is a bit steep, iirc K2 is about £55 + Vat and Delivery.
    Chris
  3. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    Is it not possible to buy from you and fit myself? If not how much do they charge to fit?
    The website says Vesa 200x200, how come 200x100 fits?
  4. vex
    vex
    Mar 8, 2005
    2,905
    103
    +261
    bwfc
    You have a PM.
  5. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    Can't thank you enough Vex. I have gone through Input Integration and he is brilliant. Can't recommend you guys enough. Great price and hopefully will have tomorrow.
  6. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    No hope about it. 6.30pm, call to cofirm the bracket is on its way. :thumbsup: Use these guys they are fabulous.
  7. Y0rkie
    Y0rkie
    Sep 21, 2004
    44
    Newcastle
    I'm looking for a flat wall mount for the LE32R41BD, would appreciate any info.
  8. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    Yorkie, This is the site for you http://www.konnect2.net/
    I used a guy called Peter Tuckett at Input Integration 01844 295300.
    I plumped for the Premier Mount AM2 Swing Arm. Its awesome and for £72, received next day is a bargain.
    Have alook on the net and then give Peter a call, best bit of business I have ever done.
    Now where did I put that screw driver........
  9. mythine
    mythine
    I bought a wall mount for a 30/ 42" TV from Richard Page, email address
    [email protected]. I was amazed at the quality and price (around £40
    post free). One of my best-ever buys! Contact him - you won't be disappointed.
  10. Y0rkie
    Y0rkie
    Sep 21, 2004
    44
    Newcastle
    Thanks for the info mythine, will look into it.
  11. Babybadger
    Babybadger
    Mar 14, 2006
    17
  12. vex
    vex
    Mar 8, 2005
    2,905
    103
    +261
    Babybadger, Thats massive!
    For a LCD tv it is way over the top both in spec and price.
    It is all down to screen type (Plasma's are very heavy) and your wall type. If you need to spread the load over a large area, due to a weak wall they work well, but if you have a solid wall and a LCD screen, something like the AM-2 or even the PTM works really well.
    And well under those Plasma Centre prices.
    Chris.
  13. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    Even had some help over the phone from Input Integration.
    Best Service Ever. One piece of advice, list to Vex.
  14. bwfc0907
    bwfc0907
    Feb 4, 2006
    1,253
    Bolton
    +49
    Here are my results of using the Premier Mount AM2 on a 32" Samsung.
    Will get some more pictures sorted over the weekend.
    Thanks to Vex at http://www.konnect2.net/
