Wall mounting Bookshelf Speakers?
Discussion in 'Home Cinema Speakers' started by horribleman, Nov 1, 2005.
  1. horribleman
    horribleman
    Jan 28, 2005
    527
    28
    +47
    Is this a good idea? I'd like to have mine attached to the wall level with the top of my 44" TV, but stands won't work as the TV unit is obstructing.
    Any recommendations on cheapish decent wall brackets?
    Thanks.
  2. Knyght_byte
    Knyght_byte
    Nov 4, 2004
    11,033
    Harrow, NW London
    +600
    depends on how heavy the speakers are and how bassy they go....
    if they are heavy or bassy you might find its wiser to use a shelf rather than bracket...with a good couple of supports....
    if not so heavy or bassy, then try richer sounds, they might have some simple brackets with plates, just make sure you find a way to affix the speaker to the plate, either spikes or lots of blue tac...lol
  3. karlak
    karlak
    Sep 4, 2005
    2,944
    +2,573
  4. BenW
    BenW
    Jun 3, 2005
    888
    Stansted
    +17
    They are hugely overpriced for what they are.
    I personally wouldny mount my speakers on anything but metal brackets
