Wall mounting B&W 600s3
Discussion in 'Home Cinema Speakers' started by danfrance110, Oct 4, 2003.
  1. danfrance110
    danfrance110
    Does anybody know if I can wall mount these speakers horizontally like a centre speaker and does it affect the sound in any way?
    Dan
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    The fixed bracket on the rear of the speakers won't allow horizontal mounting... Shouldn't be a problem horizontally as a rear effects, wouldn't recommend if you plan to run as fronts...
