Wall mounting an lcd advice please
Discussion in 'Home Cinema Buying & Building' started by markj40, Mar 13, 2006.
  1. markj40
    markj40
    Just how easy and practical is it to wall mount your lcd tv. I have a 26inch sammy with sky plus and dvd recorder, my living room isn't the biggest in the world and the only possible place to mount it would be over the fire place which would only give me a maximum viewing distance of about 7 feet,would this be enough distance? Also if i ever had the fire on would it affect the tv.Then there's the problem of all the cables which would be comming from the tv down to the unit with the sky and dvd on, can't help thinking it would look a right mess. If anyone has wall mounted their tv i would be greatfull for any advice and tips please....cheers,
    Mark
