Wall Mounting Advice
Discussion in 'Home Cinema Building DIY' started by mark88, Mar 17, 2005.
  1. mark88
    mark88
    Oct 25, 2004
    878
    +23
    I want to mount a Sharp 26" LCD TV (15.5 kg) onto my inner bedroom wall which is breeze. I already have a bracket (http://www.hifistore.co.uk/product.php?qsProd=Z846) I just now need the fixing to fix the bracket onto the wall.
    I have no idea really what to use, whether I need to use screwes+washers or will I need something a bit stronger like anchors? I also arent too use on what length and diametre screws I need. Can anyone with any experience please advise?
  2. John
    John
    Dec 13, 2002
    11,685
    +3,353
    Fischer Twistlocks are what you want .
    Try a search , look for a website set up by a guy called JasonJo , its about wallmounting a Plasma , but its the same priciple :smashin:
    atb
    JS
