sapper
Established Member
Hi peeps,
I am still contemplating the possibility of a projector and the various aspects that this covers.
In addition to deciding the actual projector and screen, there are other considerations to, well consider including
So the most practical approach is to mount the unit on the back wall and to lead the cabling round hidden by trunking.
However, should I make a shelf or buy a specialist mount such as this from vogels.
I guess if one uses a shelf, it is easier to swap the projector with out having to move the mount an inch to get the centre of the lens as close to the centre of the screen as possible.
I would value your expereinces and ideas.
Adrian
- cable lengths and type
- HDMI switching units
- hiding the cable - use of trunking
- Darkening the room - black out blinds and night time
- mounting the projector
Adrian
