Wall mounting a plasma screen
AV Geeza
Those of you that have already done this (on a solid wall), can you let me know what type, depth and size of wall plugs/bolts you used .
Im looking at getting some expanding/anchor type bolts but I think that this may well be overkill.
My heavy double radiotors are fixed using regular wall plugs, hence my my overkill statement.
For reference I have a 42" screen and have the wall bracket from the powerbuy.
Any tips and advice would be appreciated.
TIA :smashin:
BKATZ
Well, I used (504 & powerbuy wall mount)
8 x "plasplugs" M8 x 80mm Hammer-in Concrete & Brick fixings.
(bought from Homebase) Into solid brick wall.
You can hang a tank from it !:D (no witty comments please!)
Regards,
B.:)
symanski
Go for over kill. Much better than the alternative!
The problem with rawplugs is that if you don't get the right, they don't hold at all. So I'd use the largest that you can up in the wall, without going through. I've seen radiators hanging on - just. And I wouldn't want that for my screen.
All the best,
John.
E
embees
My wall runs in front of my stair case, i used coach screws from a packaging pallet, its solid as. Is there anything to breach into behind the plaster.
cruncher75
my instrutions told me to use 70mm rawplugs and 70mm size 12 screws which i got from B&Q once the mount was up i just pulled my self up on it to c if it would hold me its been up a week and is still there
Podcast: Marantz SR7015 & NAD T 778 AVR + Mission LX2 MKII Speaker Reviews, AV & Film News and More
