Wall mounting a Pioneer PDP504
Discussion in 'Home Cinema Buying & Building' started by Moviebuff, Nov 8, 2004.
  1. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +264
    I have acquired a used Pioneer wall mount off of eBay for 50 quid - it arrived with everything bar the bolts to mount it to the wall.Can anybody recommend what type,and how many bolts or screws I need to fix the bracket to a block wall,that would enable the mount to safely support a PDP504 (38 KGSs).
    Many thanks in advance.
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
  3. mikeycrawford
    mikeycrawford
    Nov 27, 2002
    116
    I bought the fischer plugs for mounting my 504HDE, only to find I didn't have an aircrete wall ... money well spent ... NOT!!! PM me with your e-mail address and I will stick them in the post for you. You will have to source your own screws mind ....
    Mike
  4. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +264
    Many thanks Simon,and also for your kind offer Mike - alas,me being trigger happy ,ordered 20 off of the Screwfix link that Simon provided.
    Thanks anyway mate,your offer was much appreciated. :thumbsup:
    This leads me on to my next question - how many do I realistically need to use to safely make good the wall bracket.
    Thanks again guys.
  5. V5-APS
    V5-APS
    May 7, 2001
    681
    London
    +15
    SimonO....are the expanding type bolts ok for solid brick walls ??
  6. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    Not really IMO, I would only recommend them for concrete... Fischer plugs and over-size coach screws are best for brick, or the above frame fixings will hang an elephant...
    This is MY opinion, if in doubt ask a qualified builder or better still phone Fischer tech support...
  7. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    How many holes are there in your bracket as that's the number to use..! I have a Unicol bracket with six fixings and I can hang on it... If you go onto the Fischer website you can download the specs for the various fixings which give their load bearing capabilities...
  8. Moviebuff
    Moviebuff
    Aug 10, 2004
    2,118
    Southampton
    +264
    Thanks Simon - I'll check it out.
    My bracket doesn't have holes - just loads of long elongated slots.
    Best course of action is to check the load rating,as you mentioned,and I will add a few for luck !!!
