Wall Mounting 507XD help!
Discussion in 'Plasma TVs Forum' started by cliffp, Jan 4, 2007.
  1. cliffp
    cliffp
    Apr 19, 2005
    43
    I have a 507XD with wall bracket (the pio one) and want to mount it to a brick wall. I was wondering what length of screw I should use and whether ordinary rawl type plugs would be ok (I was going to use 5 screws - one at each corner and one at top dead center). I did search the mounting section of the forums honest!
  2. SPANKYSPANGLER
    SPANKYSPANGLER
    Jan 4, 2007
    135
    ALDERSHOT
    +15
    DONT whatever you do just use ordinary rawl plugs - so not substantial enough.
    What you need to use is expanding bolts - and use the longest ones you can get away with regarding the thickness of the wall.
    The longer length will give a stronger fixing and will prevent any loosening or breakout that a short bolt could cause.
    I would use at least six bolts for maximum security but there is no harm in using more if you feel it is necessary - better to be safe than sorry !
    I would recommend that you try to get at least 4 inches of the bolt in the wall if the wall thickness permits this.
  3. cliffp
    cliffp
    Apr 19, 2005
    43
    Thanks a lot - Ill look in B & Q tomorrow
  4. smjxm09
    smjxm09
    May 27, 2006
    1,385
    48
    +81
    Nothing wrong with ralwplugs, just use 5 screws which are 2 inch long x12 wide or 2 and a half x 10. Each screw only has to support 16lbs.
  5. chaparral
    chaparral
    Apr 8, 2006
    1,972
    Planet Earth
    +366
    These are what holding my plasma up....(been up over 6 months now)
    Nyon plugs,Size 10mm..(drill diameter 10mm,hole depth 55mm)
    Requires 6-8mm srcews (i used 8mm coach bolts,I used five of them..I can't remember if the coach bolts i used were 50mm or 60mm long)
    [​IMG]
