Wall mounted plasma - speaker placement
Discussion in 'Home Cinema Buying & Building' started by gstadt, Sep 6, 2005.
  1. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    Morning all,
    just about to mount my plasma above a space where a hole-in-the-wall fire is going to go. Before I get started I've a couple of queries re: wall mounted speaker placement.
    Firstly, I see that most people have their centre mounted below the panel but above the fireplace. Is there better dialogue distribution lke this or will it make it worse if its above the plasma like some have done to minimise plasma height form the floor?
    Fronts seem to be accepted to go either side of the screen - no issue.
    Rear speakers - should these be just above head height when sitting down or is it better that they're higher up and more consistent with other speaker placement.
    Just about to start chasing out Edwardian solid brick walls so thought it better to be sure :D
  2. gstadt
    gstadt
    Sep 22, 2004
    270
    Cardiff
    +10
    anyone??
