Wall mounted Plasma - help needed
Discussion in 'Home Cinema Buying & Building' started by LaurieG, Sep 1, 2005.
  1. LaurieG
    LaurieG
    I'm putting my Plasma on the wall, but not knowing much about all the connections at the back, I would really appreciate some help with what cables I need to bury in the wall.
    I've got an LG 42PX3RV, DVD player (soon to be replaced to a HDD/DVD recorder) and a VCR (which I probably won't use once I get the new DVD recorder).
    After reading some posts on these threads, I've got as far as buying the bracket and installing a fused spur (which will be hidden when the TV is on the bracket). Now I’m stuck. I've started to channel out for the cables (I'm keeping them separate from the mains cable) but don't know which cables to buy. I don't want to buy cables I'm never going to need as the cable run from the TV to the DVD & VCR is quite long and it may start getting expensive.
    Thanks in advance for any help.
